Введение
How to remove or replace CD/DVD drives for the Dell Desktop XPS 420.
Выберете то, что вам нужно
Stand your case upright in an area with some space.
Remove the side panel by pushing the release on the top of the case outwards. Once the side panel is released, remove it and set it aside.
This is the drive release mechanism, adjacent to the drive panel and the drive bay.
Release the drive panel by pulling down on the drive release mechanism.
There is a single screw on the right-hand side of the drive that fits into the drive release mechanism.
Simultaneously pull down on the drive release mechanism and pull the drive gently out of the drive bay.
If you wish to insert a different CD/DVD drive, make sure the screws are set in this orientation:
One screw on the right-hand side.
Two screws on the left-hand side.
The screws will slide into these slits in the drive bay interior.
6 участников успешно повторили данное руководство.
