Введение
Перейти к шагу 1 ↓Replace the interface buttons if they have fallen out or are worn out from usage.
Выберете то, что Вам нужно
Инструменты
Lay the monitor screen-down so the back screws are exposed.
Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
Locate the two holes on the bottom of the monitor.
Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
Continue prying along the entire edge of the monitor.
When finished prying, the plastic will partially fall away from the rest of the monitor.
While holding the frames together, carefully flip the monitor over so it faces screen down.
Gently lift and remove remove the rear case from the monitor.
Locate the green interface button board.
Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
Lift the monitor interior away from the front cover.
Behind the front panel of the plastic cover lies the button strip.
Remove the buttons by gently pulling up on the strip.
Еще один человек закончил это руководство.
1 Комментарий к руководству
and then…?! you cant buy replacement buttons!! so now what?!
