Введение
If your Dell Inspiron 3542 laptop has stopped or if you just need to upgrade your system with new components, use this guide to replace the motherboard. The motherboard is responsible for overall performance, and your laptop will load a lot faster. If the motherboard stops working, then the entire system will begin to fail, including fans, lights, and more.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Выберете то, что вам нужно
Slide the latches on both sides of the laptop outward to unlock the battery.
Remove the battery from the computer.
Remove the screw. (1 x M2 x 3mm)
Move the hard drive to the open area and remove it.
Unplug the black and white antenna cables from the wireless card.
Remove the wireless card from the laptop.
Remove all screws from the bottom of the laptop. (10 x M2.5 x 5mm)
Turn over the laptop and open it.
Use the plastic prying device to release the keyboard.
Lift the keyboard.
Unplug the cable connecting the keyboard to the laptop.
Remove the keyboard.
Unplug the touch pad cables located on the palm rest.
Remove the screws. (3 x M2.5 x 5mm)
Carefully unsnap the palm rest from the rest of the laptop.
Remove the palm rest.
Unplug the cable that connects to the motherboard.
Remove the DC jack from the laptop.
Remove the screws. (1 x M2 x 3mm)
Unplug the circuit board from the rest of the computer.
Unplug the cable on the bottom part of the mother board.
Remove the screws.
Remove the cable on the right side of the motherboard. (3x M2.5 x 5mm)
Remove the motherboard from the laptop.
5 участников успешно повторили данное руководство.
Один комментарий
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
