Dell Inspiron 11-3138 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 11-3138 Hard Drive Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before Working Inside Your Computer" After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the palm-rest assembly.
  2. Dell Inspiron 11-3138 Hard Drive Replacement, Disconnecting the Hard Drive Cable: шаг 2, изображение 1 из 2 Dell Inspiron 11-3138 Hard Drive Replacement, Disconnecting the Hard Drive Cable: шаг 2, изображение 2 из 2
    • Using the pull-tab, disconnect the hard drive cable from the system board.
  3. Dell Inspiron 11-3138 Hard Drive Replacement, Lifting the Hard-Drive Assembly: шаг 3, изображение 1 из 1
    • Lift the hard-drive assembly, along with its cable, off the palm-rest assembly.
  4. Dell Inspiron 11-3138 Hard Drive Replacement, Disconnect the Interposer: шаг 4, изображение 1 из 1
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 11-3138 Hard Drive Replacement, Remove the Screws: шаг 5, изображение 1 из 1
    • Remove the screws that secure the hard-drive brackets to the hard drive.
  6. Dell Inspiron 11-3138 Hard Drive Replacement, Align the Screw Holes: шаг 6, изображение 1 из 1
    • Align the screw holes on the NEW hard drive with the screw holes on the hard-drive bracket.
  7. Dell Inspiron 11-3138 Hard Drive Replacement, Replace the Screws: шаг 7, изображение 1 из 1
    • Replace the screws that secure the hard-drive brackets to the hard drive.
  8. Dell Inspiron 11-3138 Hard Drive Replacement, Connect the Interposer: шаг 8, изображение 1 из 1
    • Connect the interposer to the hard drive.
  9. Dell Inspiron 11-3138 Hard Drive Replacement, Align the Screw Holes: шаг 9, изображение 1 из 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  10. Dell Inspiron 11-3138 Hard Drive Replacement, Replace the Screws: шаг 10, изображение 1 из 1
    • Replace the screws that secure the hard-drive assembly to the palm-rest assembly.
  11. Dell Inspiron 11-3138 Hard Drive Replacement, Connecting the Hard-Drive Cable: шаг 11, изображение 1 из 1
    • Connect the hard-drive cable to the system board.
Заключение
Terrence15
Участник с: 12/18/17
79 031 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 374
