Введение
In this guide, we will be showing you how to remove and replace the Memory Modules.
Выберете то, что вам нужно
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at an angle and press the memory module down until it clicks into place.
