Введение
This guide will show you how to replace the hard drive of the Dell Inspiron 11-3168. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Note: This guide does not apply to Celeron eMMC systems. These have the storage space soldered to the board and require a motherboard replacement.
Выберете то, что вам нужно
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
2 участников успешно повторили данное руководство.
