Введение
In this guide, we will be showing you how to remove and replace the Memory Modules.
Выберете то, что вам нужно
Loosen the captive screw (labeled "M") in the memory module cover, and lift the cover away from the computer.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Align the notch in the module edge connector with the tab in the connector slot.
Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
