Введение
One of the common defects that Dell Inspiron 13 7378 is currently facing has been the complete shut off or pitch-black screen that pops out of nowhere. That may have a lot to do with the battery and could also potentially mean it's damaged.
Before following this guide make sure the device is powered off as this can be a dangerous hazard. You will then be able to safely replace your battery and return your computer back to its proper function.
Выберете то, что вам нужно
Set the laptop with its underside facing up for improved accessibility.
Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
Carefully pry open the back of the back of the laptop using opening picks.
Carefully raise and detach the back cover from the laptop.
Remove the four screws from the battery using a Phillips #00 screwdriver.
Replace the back cover to complete the process.
6 участников успешно повторили данное руководство.
