Введение
In this guide, we will show you how to remove and replace the Hard Drive.
Выберете то, что вам нужно
Remove the screw that secures the hard-drive assembly to the system board.
Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
Lift the hard-drive assembly off the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Lift the hard-drive bracket away from the hard drive.
Replace the four screws that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly on the system board.
Slide and connect the hard-drive assembly to the system board connector.
Replace the screw that secures the hard-drive assembly to the system board.
