Введение
Is your computer experiencing trouble with connecting to the internet? Consider using this guide to replace the network adapter card in your laptop.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the 9.6 mm screws securing the back plate of the laptop.
Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
Disconnect the cable connecting the battery to the motherboard, and then remove the battery
Use a Phillips #0 screwdriver to remove the 3mm screw and the metal bracket that holds the network adapter card in place.
Pull out the network card.
To completely remove the network card, disconnect the two cords (white and black) from the adapter card. White on 1 and Black on 2.
Еще один человек закончил это руководство.
