Введение
This guide will provide information needed to replace your Dell Inspiron 13-7359 hard drive. You will need a phillips #0 screwdriver and a small plastic spudger.
Выберете то, что вам нужно
Flip your device over so the back cover is facing you.
Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
Lift and hold the hard drive in your left hand.
Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
6 участников успешно повторили данное руководство.
