Dell Inspiron 13-7373 Fan Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: шаг 1, изображение 1 из 3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: шаг 1, изображение 2 из 3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: шаг 1, изображение 3 из 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: шаг 2, изображение 1 из 1
    • Remove the two screws holding the cover for the fan.
  3. Dell Inspiron 13-7373 Fan Replacement: шаг 3, изображение 1 из 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
Заключение
To reassemble your device with the new fan, follow these instructions in reverse order.
2 участников успешно повторили данное руководство.
Kameron Jusseaume
Участник с: 10/25/19
465 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Участник UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
3 членов
Автор 5 руководств
2 Комментариев
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - Ответить
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 14
За всё время: 1,181
