Введение
In this guide, we will show you how to remove and replace the Memory Module.
Выберете то, что вам нужно
Ground yourself by touching one of the metal connectors on the back of the computer.
Turn the computer over, loosen the captive screws on the memory module/Mini PCI cover, and then remove the cover.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Align the notch in the module edge connector with the tab in the connector slot.
Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
Replace the memory module/Mini PCI cover and tighten the screws.
Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
