Dell Inspiron 13z N301z Hard-Drive Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Removing the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Connector Latch: шаг 2, изображение 1 из 1
    • Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
  3. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: шаг 3, изображение 1 из 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Remove the Screws: шаг 4, изображение 1 из 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: шаг 5, изображение 1 из 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: шаг 5, изображение 2 из 2
    • Lift the hard drive out of the hard-drive bracket.
  6. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Disconnecting the Interposer: шаг 6, изображение 1 из 1
    • Pull the interposer to disconnect it from the hard drive.
  7. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Connecting the Interposer: шаг 7, изображение 1 из 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: шаг 8, изображение 1 из 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: шаг 8, изображение 2 из 2
    • Place the hard drive in the hard-drive bracket.
  9. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: шаг 9, изображение 1 из 1
    • Replace the four screws the hard-drive bracket to the hard drive.
  10. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive Assembly: шаг 10, изображение 1 из 1
    • Place the hard-drive assembly in the computer base.
  11. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Cable: шаг 11, изображение 1 из 1
    • Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
  12. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: шаг 12, изображение 1 из 1
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Финишная черта
Еще один человек закончил это руководство.
Terrence15
Участник с: 12/18/17
79 131 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 986 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 212
