Введение
In this guide, we will show you how to remove and replace the Hard-Drive Assembly.
Выберете то, что вам нужно
Remove the screw that secures the hard-drive assembly to the computer base.
To avoid damage to the hard drive, gently slide the hard-drive bracket away from the hard-drive slot.
Lift the hard-drive assembly off the computer base.
Remove the two screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the two screws that secure the hard-drive bracket to the hard drive.
Place the NEW hard-drive assembly in the computer base.
Slide the hard-drive assembly into the connector on the system board.
Replace the screw that secures the hard-drive assembly to the computer base.
