Введение
In this guide, we will show you how to remove and replace the Memory Modules.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab in the memory module connector.
Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down on both sides until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
