Dell Inspiron 14 3467 Hard-Drive Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Hard-Drive: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in [http://n Before working inside your computer.]
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch, and disconnect the hard-drive cable from the connector on the system board.
  2. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Two Screws: шаг 2, изображение 1 из 1
    • Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Hard-Drive  Replacement, Lifting The Hard-Drive: шаг 3, изображение 1 из 1
    • Lift the hard-drive assembly along with its cable off the palm-rest assembly.
  4. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Four Screws: шаг 4, изображение 1 из 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  5. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Hard-Drive Bracket: шаг 5, изображение 1 из 1
    • Lift the hard-drive assembly off the hard-drive bracket.
  6. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Interposer: шаг 6, изображение 1 из 1
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3467 Hard-Drive  Replacement, Connecting The Interposer: шаг 7, изображение 1 из 1
    • Connect the interposer to the NEW hard drive
  8. Dell Inspiron 14 3467 Hard-Drive  Replacement, Aligning The Screws: шаг 8, изображение 1 из 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  9. Dell Inspiron 14 3467 Hard-Drive  Replacement, Screwing The Bracket To Hard-Drive: шаг 9, изображение 1 из 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  10. Dell Inspiron 14 3467 Hard-Drive  Replacement, Securing To Hard-Drive Assembly: шаг 10, изображение 1 из 1
    • Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Заключение
darrius
Участник с: 03/26/18
5 213 Репутация
Автор 30 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 24
За всё время: 3,131
