Введение
How To Remove And Replace The Memory Module
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Remove the memory module from the memory-module slot.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the NEW memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
Еще один человек закончил это руководство.
