Dell Inspiron 14 7447 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 14 7447 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 14 7447 Hard Drive Replacement, Remove the Screws: шаг 2, изображение 1 из 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14 7447 Hard Drive Replacement, Lifting the Hard-Drive Assembly: шаг 3, изображение 1 из 1
    • Gently lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 14 7447 Hard Drive Replacement, Disconnecting the Interposer: шаг 4, изображение 1 из 1
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 14 7447 Hard Drive Replacement, Remove the Screws: шаг 5, изображение 1 из 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 14 7447 Hard Drive Replacement, Lifting the Hard Drive: шаг 6, изображение 1 из 2 Dell Inspiron 14 7447 Hard Drive Replacement, Lifting the Hard Drive: шаг 6, изображение 2 из 2
    • Lift the hard drive out of the hard-drive bracket.
  7. Dell Inspiron 14 7447 Hard Drive Replacement, Connecting the Interposer: шаг 7, изображение 1 из 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 7447 Hard Drive Replacement, Align the Screw Holes: шаг 8, изображение 1 из 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 7447 Hard Drive Replacement, Replace the Screws: шаг 9, изображение 1 из 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 7447 Hard Drive Replacement, Placing the Hard-Drive: шаг 10, изображение 1 из 1
    • Place the hard-drive assembly into the hard-drive bay.
  11. Dell Inspiron 14 7447 Hard Drive Replacement, Align the Screw Holes: шаг 11, изображение 1 из 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Dell Inspiron 14 7447 Hard Drive Replacement, Replace the Screws: шаг 12, изображение 1 из 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 14 7447 Hard Drive Replacement, Connecting the Hard-Drive Cable: шаг 13, изображение 1 из 1
    • Connect the hard-drive cable to the system board.
Заключение
Terrence15
Участник с: 12/18/17
79 585 Репутация
Автор 441 руководств
Команду
RampUP America, Inc. Участник RampUP America, Inc.
Community
43 членов
Автор 1 985 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 1,216
