Dell Inspiron 14 7460 Display Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 14 7460 Display Assembly Replacement, Remove the Antenna Cables: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Note the routing and remove the antenna cables from the routing guides on the fan.
  2. Dell Inspiron 14 7460 Display Assembly Replacement, Disconnecting the Display Cables: шаг 2, изображение 1 из 1
    • Open the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 14 7460 Display Assembly Replacement, Placing the Computer: шаг 3, изображение 1 из 1
    • Open the display at an angle of 90 degrees.
    • Place the computer on the edge of a table so that the palm rest and keyboard assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  4. Dell Inspiron 14 7460 Display Assembly Replacement, Remove the Screws: шаг 4, изображение 1 из 1
    • Remove the four screws (M2.5x5) that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 14 7460 Display Assembly Replacement, Lifting the Display Assembly: шаг 5, изображение 1 из 2 Dell Inspiron 14 7460 Display Assembly Replacement, Lifting the Display Assembly: шаг 5, изображение 2 из 2
    • Lift the display assembly off the palm rest and keyboard assembly.
  6. Dell Inspiron 14 7460 Display Assembly Replacement, Placing the Palm Rest: шаг 6, изображение 1 из 1
    • Place the palm rest and keyboard assembly on the edge of a table with the keyboard facing down.
  7. Dell Inspiron 14 7460 Display Assembly Replacement, Align the Screw Holes: шаг 7, изображение 1 из 1
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  8. Dell Inspiron 14 7460 Display Assembly Replacement, Replace the Screws: шаг 8, изображение 1 из 1
    • Replace the four screws (M2.5x5) that secure the NEW display assembly to the palm rest and keyboard assembly.
  9. Dell Inspiron 14 7460 Display Assembly Replacement, Securing the Display Cable: шаг 9, изображение 1 из 1
    • Close the display and turn the computer over.
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  10. Dell Inspiron 14 7460 Display Assembly Replacement, Routing the Antenna Cables: шаг 10, изображение 1 из 1
    • Route the antenna cables through the routing guides on the fan.
Заключение
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 17
За всё время: 1,468
