Введение
In this guide, we will show you how to remove and replace the Memory Modules.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory- module slot and slide the memory module firmly into the slot at an angle.
Press the memory module down until it clicks into place.
Почти готово!
Финишная черта
