Введение
In this guide, we will show you how to remove and replace the Display Assembly.
Выберете то, что вам нужно
Disconnect the display cable from the connector on the system board.
Remove the two screws (one on each side) that secure the display assembly to the computer base.
Lift and remove the display assembly out of the computer base.
Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
Connect the display cable to the connector on the system board.
Почти готово!
Финишная черта
