Введение
The Coin-Cell Battery is a power source for the motherboard while the computer is off. It is used to keep track of the system clock.
Выберете то, что вам нужно
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Lift the coin cell battery wire, and carefully remove from motherboard.
Еще один человек закончил это руководство.
