Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Do you find that your computer overheats frequently? Your heat sink may be faulty, which would cause your processor to run hotter than it should. Replacing your heat sink is very simple and can be done with the help of this guide.
Запчасти
Детали не указаны.
  1. Slide the two tabs to release the battery. Pull the battery out. Pull the battery out.
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Using a Phillips #00 screwdriver, remove the three 5mm screws. Lift the panel and set it aside. Lift the panel and set it aside.
    • Using a Phillips #00 screwdriver, remove the three 5mm screws.
    • Lift the panel and set it aside.
  4. Remove the four screws (3mm) securing the heat sink to the CPU. Lift the Heat sink out of the laptop. Lift the Heat sink out of the laptop.
    • Remove the four screws (3mm) securing the heat sink to the CPU.
    • Lift the Heat sink out of the laptop.
Заключение
David Nunez
Участник с: 23.09.2014
37 Репутация
1 руководство автора
Команда
USF Tampa, Team 2-4, Blackwell Fall 2014 Участник USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 764
