Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Do you find your laptop is running slowly when you have multiple programs running? You may find the solution simpler than you may think. By upgrading your RAM, your computer may see some improvements in speed and performance.
  1. Slide the two tabs to release the battery. Pull the battery out. Pull the battery out.
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Using a Phillips #00 screwdriver, remove the three 2.5mm screws from the panel. Pull back the panel and set it aside. Pull back the panel and set it aside.
    • Using a Phillips #00 screwdriver, remove the three 2.5mm screws from the panel.
    • Pull back the panel and set it aside.
  4. Spread apart the securing clips on both ends of the chip until the module pops out. Remove the RAM from the connector. These represent the clips of a second module
    • Spread apart the securing clips on both ends of the chip until the module pops out.
    • Remove the RAM from the connector.
    • These represent the clips of a second module
Заключение
Еще один человек закончил это руководство.
Shaun Dinsmore
Участник с: 23.09.2014
52 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-4, Blackwell Fall 2014 Участник USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 695
