Dell Inspiron 1428 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive cover to the computer base.
  2. Dell Inspiron 1428 Hard Drive Replacement, Pry out te Hard-Drive Cover: шаг 2, изображение 1 из 1
    • Pry out the hard-drive cover using your finger.
  3. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: шаг 3, изображение 1 из 1
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  4. Dell Inspiron 1428 Hard Drive Replacement, Disconnecting the Hard Drive Assembly: шаг 4, изображение 1 из 1
    • Pull the pull-tab on the hard-drive assembly towards the right to disconnect the hard-drive assembly from the system board connector.
  5. Dell Inspiron 1428 Hard Drive Replacement, Lifting the Hard-Drive Assembly: шаг 5, изображение 1 из 1
    • Lift the hard-drive assembly out of the computer base.
  6. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: шаг 6, изображение 1 из 1
    • Remove the four screws that secure the hard drive to the hard-drive cage.
  7. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard Drive: шаг 7, изображение 1 из 1
    • Place the NEW hard drive in the hard-drive cage.
  8. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: шаг 8, изображение 1 из 1
    • Replace the four screws that secure the hard drive to the hard-drive cage.
  9. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard-Drive Assembly: шаг 9, изображение 1 из 1
    • Place the NEW hard-drive assembly in the computer base.
  10. Dell Inspiron 1428 Hard Drive Replacement, Connecting the Hard-Drive Assembly: шаг 10, изображение 1 из 1
    • Slide and connect the hard-drive assembly to the system board connector.
  11. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: шаг 11, изображение 1 из 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 1428 Hard Drive Replacement, Align the Tabs: шаг 12, изображение 1 из 1
    • Align the tabs on the hard-drive cover with the slots on the computer base and snap the hard-drive cover into place.
  13. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: шаг 13, изображение 1 из 1
    • Replace the two screws that secure the hard-drive cover to the computer base.
Финишная черта
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 67
