Dell Inspiron 14z 1470 Display Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: шаг 1, изображение 1 из 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: шаг 1, изображение 2 из 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws on the base of the computer that secure the display assembly to the computer base.
  2. Dell Inspiron 14z 1470 Display Assembly Replacement, Disconnecting the Display Cable: шаг 2, изображение 1 из 1
    • Disconnect the display cable and remove the screw from the system board.
  3. Dell Inspiron 14z 1470 Display Assembly Replacement, Pull the Antenna Cables: шаг 3, изображение 1 из 1
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 14z 1470 Display Assembly Replacement, Note the Routing: шаг 4, изображение 1 из 1
    • Note the routing of all the cables and remove them from their routing guides.
  5. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: шаг 5, изображение 1 из 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: шаг 5, изображение 2 из 2
    • Hold the display while you remove the three screws that secure the display assembly to the computer base.
  6. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display Assembly: шаг 6, изображение 1 из 1
    • Lift and remove the display assembly from the computer base.
  7. Dell Inspiron 14z 1470 Display Assembly Replacement, Place the Display Assembly: шаг 7, изображение 1 из 1
    • Using the alignment posts, place the NEW display assembly in position and replace the three screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14z 1470 Display Assembly Replacement, Routing the Antenna Cables: шаг 8, изображение 1 из 1
    • Route the Mini-Card antenna cables and display cable through their routing guides.
  9. Dell Inspiron 14z 1470 Display Assembly Replacement, Route the Antenna Cables: шаг 9, изображение 1 из 1
    • Route the antenna cables through the slot in the computer base.
  10. Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: шаг 10, изображение 1 из 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: шаг 10, изображение 2 из 2
    • Replace the screw and connect the display cable.
Финишная черта
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 236
