Введение
Before starting this guide, make sure your laptop is powered completely off and detached from the power cable. This replacement will be helpful to learn for replacing most other components of the laptop, as well as, replacing the battery itself.
Close the laptop and place it so that the back of the screen is lying flat on your work surface.
Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
Lift the battery at an angle using your fingertips and remove it from the laptop.
3 человек успешно провели ремонт по этому руководству.
2 Комментариев
Can you do a guide on how to change a CPU on this computer?
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
