Введение
In this guide, we will show you how to remove and replace the Display Assembly.
Запчасти
Никакие детали не требуются.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  2. Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base. Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Note the display cable routing and remove the cable from its routing guides on the computer base.
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Remove the screws that secure the display hinges to the computer base.
    • Remove the screws that secure the display hinges to the computer base.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Carefully lift the display assembly off the computer base.
    • Carefully lift the display assembly off the computer base.
  7. Align the screw holes on the display hinges with the screw holes on the computer base.
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  8. Replace the screws that secure the display hinges to the computer base.
    • Replace the screws that secure the display hinges to the computer base.
  9. Route the display cable through its routing guides on the computer base. Route the display cable through its routing guides on the computer base.
    • Route the display cable through its routing guides on the computer base.
  10. Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Финишная черта
Terrence15
Участник с: 18.12.2017
70 643 Репутация
Автор 442 руководств
Команда
Informative Technologies Inc. Member of Informative Technologies Inc.
Community
15 членов
Автор 925 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 7
За 30 дней: 23
За всё время: 217
