Введение
In this guide, we will be showing you how to remove and replace the Display Assembly.
Выберете то, что вам нужно
Using the pull tab, disconnect the display cable from the system board.
Note the display-cable routing and remove the cable from the routing guides on the computer base.
Disconnect the antenna cables from the wireless card.
Note the antenna-cable routing and remove the antenna cables from the routing guides on the computer base.
Slide the display cable and antenna cables through the slots on the computer base.
Remove the four screws (M2x5) that secure the display assembly to the computer base.
Align the screw holes on the NEW display assembly with the screw holes on the computer base.
Replace the four screws (M2x5) that secure the display assembly to the computer base.
Slide the display cable and antenna cables through the slot on the computer base.
Close the display and turn the computer over.
Route the display cable and antenna cables through the routing guides on the computer base.
