Dell Inspiron 15 5576 Gaming Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Disconnecting the Hard Drive Cable: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Screws: шаг 2, изображение 1 из 1
    • Remove the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Lifting the Hard Drive Assembly: шаг 3, изображение 1 из 1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Disconnect the Interposer: шаг 4, изображение 1 из 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Screws: шаг 5, изображение 1 из 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Hard Drive Bracket: шаг 6, изображение 1 из 1
    • Remove the hard-drive bracket off the hard drive.
  7. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Align the Screw Holes: шаг 7, изображение 1 из 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  8. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Replace the Screws: шаг 8, изображение 1 из 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Connect the Interposer: шаг 9, изображение 1 из 1
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Align the Screw Holes: шаг 10, изображение 1 из 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Replace the Screws: шаг 11, изображение 1 из 1
    • Replace the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Connect the Hard Drive Cable: шаг 12, изображение 1 из 1
    • Connect the hard-drive cable to the connector on the system board.
Финишная черта
Еще один человек закончил это руководство.
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 560
