Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Turn the Computer Over: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Placing the Computer: шаг 2, изображение 1 из 1
    • Place the computer on a flat surface with the display facing down.
  3. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Remove the Screws: шаг 3, изображение 1 из 1
    • Remove the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
  4. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Remove the Antenna Cables: шаг 4, изображение 1 из 1
    • Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Lifting the Display Assembly: шаг 5, изображение 1 из 1
    • Lift the display assembly off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Align the Screw Holes: шаг 6, изображение 1 из 1
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Replace the Screws: шаг 7, изображение 1 из 1
    • Replace the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
  8. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Turn the Computer Over: шаг 8, изображение 1 из 1
    • Turn the computer over and close the display.
Финишная черта
Еще один человек закончил это руководство.
Terrence15
Участник с: 12/18/17
79 161 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 989 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 18
За всё время: 1,768
