Введение
In this guide, we will be showing you how to remove and replace the Hard Drive.
Выберете то, что вам нужно
Remove the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
Lift the hard-drive assembly off the palm rest and keyboard assembly.
Disconnect the interposer from the hard-drive assembly.
Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
Replace the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
Еще один человек закончил это руководство.
Один комментарий
is the hard drive where the os is installed or in the m.2 drive and can i use a wd blue 512gb 3d nand ssd
