Введение
If your Dell Inspiron 15 7579 computer is overheating, freezing or glitching, and the other hardware is intact, you may need to replace its motherboard. Hazards include exposure of the motherboard and operating with small electrical wires that cannot sustain large amounts of force.
Выберете то, что вам нужно
Insert metal spudger into a gap in between the back panel and the back of the screen.
Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
