Введение
This guide will walk you through the process to remove and replace the wifi internet card in your Dell Inspiron 15 7579.
Выберете то, что вам нужно
Insert metal spudger into a gap in between the back panel and the back of the screen.
Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Remove the bracket holding the card in place by unscrewing the single 3 mm screw located in the upper left hand corner of the device using a Phillips #1 screwdriver bit.
