Dell Inspiron 15 Display Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 15 Display Assembly Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Remove the screws that secure the display hinges to the palm-rest assembly and open the hinges to an angle of 90 degrees.
  2. Dell Inspiron 15 Display Assembly Replacement, Note the Antenna Cable: шаг 2, изображение 1 из 1
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  3. Dell Inspiron 15 Display Assembly Replacement, Noting the Display Cable: шаг 3, изображение 1 из 1
    • Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
  4. Dell Inspiron 15 Display Assembly Replacement, Open the Assembly: шаг 4, изображение 1 из 1
    • Open the palm-rest assembly.
  5. Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: шаг 5, изображение 1 из 2 Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: шаг 5, изображение 2 из 2
    • Lift the palm-rest assembly at an angle off the display assembly.
  6. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: шаг 6, изображение 1 из 1
    • Place the display assembly on a clean, flat surface.
  7. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: шаг 7, изображение 1 из 1
    • Place the NEW display assembly on the palm-rest assembly.
  8. Dell Inspiron 15 Display Assembly Replacement, Close the Display Hinges: шаг 8, изображение 1 из 1
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  9. Dell Inspiron 15 Display Assembly Replacement, Replace the Screws: шаг 9, изображение 1 из 1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  10. Dell Inspiron 15 Display Assembly Replacement, Route the Display Cable: шаг 10, изображение 1 из 1
    • Route the display cable through its routing guides on the palm-rest assembly.
  11. Dell Inspiron 15 Display Assembly Replacement, Routing the Antenna Cables: шаг 11, изображение 1 из 1
    • Route the antenna cables through its routing guides on the palm-rest assembly.
    • Close the display and turn the computer over.
Финишная черта
Еще один человек закончил это руководство.
Terrence15
Участник с: 12/18/17
79 555 Репутация
Автор 441 руководств
Команду
RampUP America, Inc. Участник RampUP America, Inc.
Community
43 членов
Автор 1 985 руководств
Один комментарий
I can't replace the cables on the left side of the lid through the hinge.
Peter Meyer - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 6
За последние 30 дней: 55
За всё время: 2,294
