Dell Inspiron 15 M5030 Display Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 15 M5030 Display Assembly Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the base of the computer.
  2. Dell Inspiron 15 M5030 Display Assembly Replacement, Open the Display: шаг 2, изображение 1 из 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 15 M5030 Display Assembly Replacement, Disconnecting the Antenna Cable: шаг 3, изображение 1 из 1
    • Make a note of the Wireless Mini-Card antenna cable routing and disconnect the Wireless Mini-Card antenna cable from the Wireless Mini- Card.
  4. Dell Inspiron 15 M5030 Display Assembly Replacement, Disconnect the Display Cable: шаг 4, изображение 1 из 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  5. Dell Inspiron 15 M5030 Display Assembly Replacement, Remove the Screws: шаг 5, изображение 1 из 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 15 M5030 Display Assembly Replacement, Removing the Display Assembly: шаг 6, изображение 1 из 1
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron 15 M5030 Display Assembly Replacement, Placing the Display Assembly: шаг 7, изображение 1 из 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron 15 M5030 Display Assembly Replacement, Routing the Display Cable: шаг 8, изображение 1 из 1
    • Route the display cable into the routing guide and connect the display cable to the connector on the system board.
  9. Dell Inspiron 15 M5030 Display Assembly Replacement, Routing the Cable: шаг 9, изображение 1 из 1
    • Route the Mini-Card antenna cable into the routing guide and connect the Mini-Card antenna cable to the connector on the Mini-Card.
  10. Dell Inspiron 15 M5030 Display Assembly Replacement, Replace the Screws: шаг 10, изображение 1 из 1
    • Turn the computer over and replace the two screws at the base of the computer.
Финишная черта
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 96
