Введение
This replacement guide will explain how to insert a new memory card into the Dell Inspiron 15-3521 laptop. Keep in mind that to perform this replacement, you will be opening the interior of your device, so it is best to perform this replacement in a clean environment.
Выберете то, что вам нужно
Flip the laptop over.
Slide the latches toward the outside of the laptop to unlock the battery.
Lift the battery out of the laptop.
Loosen the two screws attaching the access door to the laptop body
Using a spudger, pry open the access door from the laptop
Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
To access the memory cards, push out the latches on the left and right of the memory cards
To remove the memory card, pull it out of the tray with the latches still stretched out
Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
7 участников успешно повторили данное руководство.
