Введение
Is the RAM in your Dell Inspiron 15-3543 defective or full? If so, here is the guide to fix the problem by simply replacing your RAM. All you need is the standard #0 Phillips Screwdriver head in order to remove the one screw involved with this replacement.
Выберете то, что вам нужно
Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of the device beside the vents.
Slide the panel off by placing your hands on top and, while using a little force, sliding your hands down.
Using two fingers, slide the two notches holding the RAM in place outwards.
After the notches are moved outwards, the RAM will pop up and it can be pulled out.
Еще один человек закончил это руководство.
