Введение
The following guide will give instructions on how to properly replace the hard drive on your Dell Inspiron 15-5552.
Выберете то, что вам нужно
Slide the battery release switch away from the lock symbol towards the “unlock” position.
Rotate the battery outward by lifting the bottom lip that pops out.
Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Use a JIS #0 screwdriver to unscrew the two 6 mm screws from the back panel.
Using a spudger, lightly lift the RAM cover up and at an angle, away from the computer.
Using two fingers, grab the black connector on the ribbon, and pull until detached.
2 участников успешно повторили данное руководство.
