Выберете то, что вам нужно
Slide the battery release switch away from the lock symbol towards the “unlock” position.
Rotate the battery outward by lifting the bottom lip that pops out.
Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Keyboard
Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Еще один человек закончил это руководство.
Один комментарий
After reading this it took all of 5 minutes to remove the key board thank you now to see why this computer will not power up!!!
