Введение
The battery is needed to power the laptop. A bad battery must be replaced, which can be done with this guide.
Выберете то, что вам нужно
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
4 участников успешно повторили данное руководство.
