Dell Inspiron 15-7537 Keyboard Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 15-7537 Keyboard Replacement, Bottom Case: шаг 1, изображение 1 из 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Keyboard Replacement: шаг 2, изображение 1 из 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Keyboard Replacement: шаг 3, изображение 1 из 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Keyboard Replacement, Battery: шаг 4, изображение 1 из 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Keyboard Replacement: шаг 5, изображение 1 из 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
  6. Dell Inspiron 15-7537 Keyboard Replacement, Removing the Keyboard: шаг 6, изображение 1 из 1
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  7. Dell Inspiron 15-7537 Keyboard Replacement: шаг 7, изображение 1 из 1
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  8. Dell Inspiron 15-7537 Keyboard Replacement: шаг 8, изображение 1 из 1
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  9. Dell Inspiron 15-7537 Keyboard Replacement: шаг 9, изображение 1 из 3 Dell Inspiron 15-7537 Keyboard Replacement: шаг 9, изображение 2 из 3 Dell Inspiron 15-7537 Keyboard Replacement: шаг 9, изображение 3 из 3
    • Take the keyboard off the palm rest assembly.
Заключение
11 участников успешно повторили данное руководство.
Jean Whitmore
Участник с: 01/22/15
984 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 18-2, Maness Winter 2015 Участник Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 членов
Автор 8 руководств
3 Комментариев
Great guide, thanks for the help!
Patrick S - Ответить
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
benton.addison - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 6,569
