Введение
Use this guide to replace the keyboard if you have determined your keyboard issues may be resolved by replacing the keyboard.
Выберете то, что вам нужно
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
Use a spudger to remove the base cover from the rest of bottom cover.
As it is not clearly visible in the picture: You should start to open the base cover at the screen side, to avoid breaking the plastic guides of the base cover. A flat dough scraper is a pretty good tool for that.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
Using the pull tab on the battery, lift the battery out of the computer.
These instructions look as if you ground the board first and then remove the battery.
I think it should be the other way round. First, remove the battery. Secondly, ground the board.
Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
Flip over the computer and open the display as far as it can go.
Use the spudger to remove the keyboard from the palm assembly.
Gently flip over the keyboard and place it on the palm rest assembly.
Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
Take the keyboard off the palm rest assembly.
I had problems open and close the clips for the Keyboard-cables. ^^ Any tips how to open and close? Thanks in advance.
11 участников успешно повторили данное руководство.
3 Комментариев
Thanks It’s Useful
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
