Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Is the sound coming out of your laptop distorted or unclear? Consider using this guide to replace the speakers in your device.
Запчасти
Детали не указаны.
  1. Unscrew the six  2.5x6mm screws and remove them using a Phillips #1 screwdriver. Loosen the four 2x3mm captive screws at the bottom.
    • Unscrew the six 2.5x6mm screws and remove them using a Phillips #1 screwdriver.
    • Loosen the four 2x3mm captive screws at the bottom.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Using the flat head side of the spudger separate the the back panel from the rest of the laptop.
    • Using the flat head side of the spudger separate the the back panel from the rest of the laptop.
    • When separating the bottom and right side of the case do not insert the spudger more than half an inch.
  3. Disconnect the battery from the motherboard by pulling the black tab attached to the cable. Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Remove the four 2.5x6mm screws using a Phillips #1 screwdriver. Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Remove the ribbon cable by pulling it out.
    • Remove the ribbon cable by pulling it out.
  6. Remove the compression caps by using the spudger. Remove the compression caps by using the spudger.
    • Remove the compression caps by using the spudger.
  7. Untangle the wire from the plastic clips and remove the speakers from the device.
    • Untangle the wire from the plastic clips and remove the speakers from the device.
Заключение
2 участников успешно повторили данное руководство.
brianna cordoway
Участник с: 26.09.2018
127 Репутация
1 руководство автора
Команда
University of North Texas, Team S7-G3, Thompson Fall 2018 Участник University of North Texas, Team S7-G3, Thompson Fall 2018
UNT-THOMPSON-F18S7G3
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 263
