Введение
Is the sound coming out of your laptop distorted or unclear? Consider using this guide to replace the speakers in your device.
Выберете то, что вам нужно
Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
Untangle the wire from the plastic clips and remove the speakers from the device.
3 участников успешно повторили данное руководство.
