Введение
This is a guide to replace the monitor on the Dell Inspiron 15-7559 laptop. Which may be necessary if your monitor fails to display images.
Запчасти
No parts specified.
  1. This next step will likely cause some of the tabs, that hold the display, to snap. They will still function and hold the display in place and there should be no noticeable issues once put back together, but the tabs will have permanent damage and repeated disassembly will most likely require replacement. Using the metal or plastic spudger pry open the frame around the display. Using the metal or plastic spudger pry open the frame around the display.
    • This next step will likely cause some of the tabs, that hold the display, to snap. They will still function and hold the display in place and there should be no noticeable issues once put back together, but the tabs will have permanent damage and repeated disassembly will most likely require replacement.
    • Using the metal or plastic spudger pry open the frame around the display.
  2. Pull the screen down and let it lie on the keyboard. Pull the screen down and let it lie on the keyboard.
    • Pull the screen down and let it lie on the keyboard.
  3. Apple Watch Kits
    Screen and battery repairs just got easier.
    Купить сейчас
    Apple Watch Kits
    Купить сейчас
  4. Locate the wire that connects the display to the back panel. There will be a sticker with a qr code on it. Peel the the sticker and pull it back to disconnect the cables. Peel the the sticker and pull it back to disconnect the cables.
    • Locate the wire that connects the display to the back panel. There will be a sticker with a qr code on it.
    • Peel the the sticker and pull it back to disconnect the cables.
  5. The display is now fully disconnected, you can now completely remove it from the computer. The display is now fully disconnected, you can now completely remove it from the computer.
    • The display is now fully disconnected, you can now completely remove it from the computer.
Заключение
Mason Ottinger
Участник с: 18.10.2017
137 Репутация
1 Guide authored
Команда
UW Tacoma, Team S3-G2, Liner Fall 2017 Member of UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 членов
Автор 8 руководств
Один комментарий
How do you replace the antenna cables around the display?
Prasanna Pokharel - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 24
За 30 дней: 147
За всё время: 3,016
