Dell Inspiron 15-7559 Repair Memory Modules Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Repair Memory Modules Replacement: шаг 2, изображение 1 из 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: шаг 2, изображение 2 из 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: шаг 2, изображение 3 из 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Repair Memory Modules Replacement: шаг 3, изображение 1 из 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: шаг 3, изображение 2 из 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: шаг 3, изображение 3 из 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Popping up the Memory Module: шаг 4, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  5. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: шаг 5, изображение 1 из 1
    • Slide and remove the memory module from the memory-module slot.
  6. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Align the Notch: шаг 6, изображение 1 из 1
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  7. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: шаг 7, изображение 1 из 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Финишная черта
2 участников успешно повторили данное руководство.
Terrence15
Участник с: 12/18/17
79 131 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 986 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 1,101
