Введение
The following guide will demonstrate how to replace the wireless card in the Dell Inspiron 15-7567. You may need to replace if your wireless connection is bad.
Выберете то, что вам нужно
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
Detach the black and white wires connected to the card by gently lifting up on the wires.
