Введение
This guide will show you how to remove the memory from your device.
Выберете то, что вам нужно
Place the laptop facedown with the battery facing you.
Push the switch above the battery to the right and hold it in that position.
Lift the battery using the grip on the top and remove it from its socket.
Pull the two metal clips holding down the card apart.
Lift and pull out the card.
Почти готово!
Заключение
